I understand that guide plates are legal when going from the OE design to a stud and poly lock.
Is the guide plate conversion talked about in the rule book, can't seem to find anything about it. Which fulcrums can I use with the OE rocker? Doing up a good set of heads and would like to do the conversion at the same time Thanks much Charlie |
Charlie, I just went thru this with my 85 Mustang. Although it may be possible to drill the factory rocker fulcrums out to 3/8 or 7/16`s, what I did was have 7/16`s studs installed, and I used a set of the factory Boss 302 , Boss 351, 429SCJ rocker fulcrums. These fulcrums are drilled for 7/16" studs, and don`t have square "lug" on the bottom, that the factory 5.0 non adjustable rockers use to keep the rocker centered over the valve. As far as I know, these fulcrums are obsolete from Ford, I happened to find a NOS set of 16 in a local car parts magazine. The Ford part number on the box of fulcrums is D0OZ-6A528-C if that helps. Maybe some Ford racer or shop might have some laying around. I`ll be racing in Sonoma, so I could show you what they look like. Good luck.
Thanks Rory, I look foward to seeing you in Sonoma, I will be there for both weekends. Maybe PartsBob could tell us if that part # is still alive today..............
Liked 79 Times in 11 Posts
i'l look tomorrow and report back in.
bob beals 7244 |
Liked 223 Times in 73 Posts
You can use older 302 rockers and ball studs with guide plates ask NHRA this question earlier this year I am also working on a set for better adjustablity. I have the email from NHRA that says it is legal.
no longer available, and no listing dealers with any nos stuff laying around. maybe check out hemmings for somebody with a set for sale. or a boss 302 restoration specialist. see you guys in sonoma.
bob beals 7244 |
Thanks for checking partsbob................
Westcoast, my next call and email will be to Glendora so I can have my own copy of that ruling................................Thanks much for the help cccccc |
#8 | |
Westcoast Just got off the phone with Pat in the tech office, his quote was "machining the rocker bosses on the head is NOT legal". Milling the pedastils to accept a screw in stud and guide plate would be the only way to locate the pushrod using the OEM style non railed rocker arm. Not really the answer I needed to hear but that is what NHRA tech told me. How can I see a copy of that email that you have? Thanks again ccccccc |
Liked 370 Times in 101 Posts
How about using Comp Cams #4504 stud with older 302 "rail rocker arms",no machining is needed for the stud, its 5/16" on the head side ,and 3/8" up top. Crane makes a rail rocker for older 302 engines,# 36801-16,I have a set that I was going to try on my old H.O combo before I went the 93 cobra route. Jegs has them.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
Liked 1,436 Times in 299 Posts
Jerry, where have you been? When are you going to come out and run with us at Heartland? Jim
James Schaechter 3163 STK |
