#41 | |
Liked 1,583 Times in 582 Posts
In the early days when cams were checked and with the early spring rules, cams where still being designed and built with "Dwell" lobes or what many call square lobes. Let's not forget the days when many ran General Kinetics Cheater cams. Almost all of Don's cam designs were dwell lobes. The cam manufacturers of the early days for cheater cams were General Kinetics, Lunati, Cam Dynamics and Eonics. Later on, other companies such as Crane, Isky and Comp Cams joined the fray when the spring rule changed. In the early days, if you had a Chevy, you ran Lunati; if you had a Mopar, you ran a GK cam; if you had a Ford, Cam Dynamics, if you had an Oldsmobile or Pontiac, you ran an Eonics cam. Although there were spring pressure limits in the early days, the specification sheets sent by the manufacturers were quite liberal especially with Mopar. The big difference on the new generation Cheater camshaft is they have faster ramps with bigger numbers in 0.200" lift area. |
#42 | |
Liked 7,758 Times in 1,741 Posts
#43 | |
Banned
Liked 235 Times in 110 Posts
#44 | |
#45 |
Banned
LOL....Well the A/SA and AA/S are quicker than the Pro stocks were in 1970 (or the 1/4 mile is shorter) on little bitty 9 inch tires, "stock heads", OEM bottom ends, and they weigh more. Its called "Progress"
#46 | |
I also believe that the valve spring rule was the turning point to begin the RUIN of the class and it's original concept. |
#47 | |
#48 |
Banned
And what does that tell you? Its not all tire technology and ring packs....Maybe the air is better today than back in the 60's and 70's?
#49 |
Liked 1,831 Times in 415 Posts
It's any number of things. Granted valve springs have allowed a lot. But clutches, carburetors, torque converters, headers, and transmissions have come a long way. There's a ton of things that have gotten better, and racers have gotten smarter because there's more information available as well. Information and knowledge make a lot of HP.
Alan Roehrich 212A G/S |
#50 |
