Old 06-07-2010, 07:54 PM   #1
art leong
Default Re: Ford 2003 6.0 diesel ???
Originally Posted by FED 387 View Post
Any problems with these engines ---heard about the injectors/egr clogging and trans problems but any other problems I should know about or watch out for???-Thanx Comp 387
90% of the people with them don't like them Thyat should tell you something.
Get a 99 to 02 7.3 they run great But the auto trannies are sometimes a problem.
Art Leong 2095 SS
Old 06-07-2010, 08:32 PM   #2
Cam
Cam's Avatar
Good source of information here:
http://powerstrokehelp.com/
Cam Chowen
6067
1994 Camaro C/S
Cam is offline   Reply With Quote
Old 06-07-2010, 08:52 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
Ditto on 6.0 problems and getting a 7.3!
Adger Smith (Former SS)
Old 06-07-2010, 09:50 PM   #4
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
I have one; same year, now has almost 300,000 kilometers(186,000 miles). No tranny issues, replaced injector seals, injector harness repair once - generally no big problems. Never installed a programmer.
Dave Turner
SS/GT #1153
Old 06-08-2010, 08:24 PM   #5
magnumv8
We run an upfitter shop and we have done hundreds of Ford diesels....starting with the 6.0 in 2003 don't touch 'em...the 7.3 is tough the 6.4 is not bad, but very hard on fuel and we are upfitting a dozen or so 6.7's, that now have UREA injection so the jury isn't in on those since they are now built by FORD and have a radical cylinder head difference from previous models....from the factory (new) the 6.0 had so many different issues most dealers couldn't repair them,we had an '03 that we bought new and in the first year we had it, it was at the dealership 8 months....they had the cab off and on so much they finally told us not to bring it back(this was under warranty, but Ford had over $500,000,000.00 in warranty claims on this engine and gave up, eventually suing International over it)....we had new trucks blow head gaskets just moving them in and out of the shop during upfitting....the spring clamps they used on the radiator hoses were broken on quite a few of them among the various other issues that would pop up on these things......they can be made to hold up, but it is REAL expensive....
I am not bashing this issue because I make my living on these things and customers demand a dependable vehicle, but the 6.0 Ford truck is making some guys a lot of money replacing the 6.0 with a Cummins engine( makes a nice package).......
D L Rambo.....
magnumv8 is offline   Reply With Quote
Old 06-08-2010, 08:29 PM   #6
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
I purchased a 2005 a year ago Christmas (F-350) with the 6.0. I am loving it more daily. I had only one issue so far with the high pressure oil that goes to the injectors, but warranty covered it. I have gotten 16-17mpg with the 3:73 gearing (4X4), on the highway and less than 15 intown. I have not pulled enough to give any thing there.
The 2005 had some changes in the chassis that made the ride a little better. I also suggest that you only get the one that has the 5 speed automatic at a minimum. It gives a better first gear for towing when starting out. My local dealer suggests that more frequent oil changes including filters really help the 6.0, and especially pay attention to the fuel filters. I have switched to a local fuel station that is seeming to produce more consistent results.
My previous owner had all records and was very meticulous with the oil changes and I weighed that into my purchase decision. Now I need a 28 footer for the car and I am ready for 11,500 towing capacity, legally.
Old 06-09-2010, 07:42 AM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,955 Times in 590 Posts
If you are thinking about purchasing a used diesel dually I would highly recomend a chevy or GMC with a duramax. They are very durable and powerful. I have a 2005 with 160,000 miles on it. I have had no problems at all with this truck. I haul a 40 ft goose w/ LQ. It weighs about 15000 lbs. 9-10 mpg towing. 17-18 just truck. The allison trans is fantastic and the brakes stop the rig flawlessly.
Mike Pearson 2485 SS
Old 06-11-2010, 09:12 AM   #8
EdgarTurbo
I have a 2000 f350 7.3, I love this truck, the only problem I got so far is the glow plugs relay( about $40 dollars) and still pulling strong, no dissapointments on this one.
Edgar
EdgarTurbo is offline   Reply With Quote
Old 06-11-2010, 07:48 PM   #9
W J
Mike, we have a '05 GMC Duramax/Allison bought new. Light towing only---all services performed. Was disappointed to lose Allison trans after a trip from Ma to NC and back. Failed off 72k warranty at 85k miles. Just put in a Allison factory re-build----very pricey project. Love the truck, but disappointed....the Allisons aren't supposed to fail that quick, just bad luck, I guess.....WJ
Old 06-08-2010, 08:45 PM   #10
CycloneFE
CycloneFE's Avatar
