Old 06-07-2010, 03:23 PM   #1
Greg Hill
Liked 279 Times in 68 Posts
Default Re: ARC switch panel UGH!!!!
I'll second that on the K&R wiring and switch panel. It's simply the best and easiest way to wire a car. I used it on Andrew's new car and plan on re-wiring my car this winter with the K&R stuff.
Greg Hill 4171 STK
Old 06-08-2010, 06:48 PM   #2
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
I have a OLD (almost antique) ARC panel and it's been flawless.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 06-08-2010, 10:00 PM   #3
treessavoy
Liked 4 Times in 4 Posts
Could it be a ground problem?
JimR
Jim Rountree
Old 06-09-2010, 07:48 AM   #4
bert powell
Liked 34 Times in 12 Posts
Not a ground problem, isolated it to the switch. Can jumper around switch and works every time. Have heard of others having the same problem with the starter switch.
bert powell is offline   Reply With Quote
Old 06-09-2010, 05:37 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
Bert,
Those switches are available for different load capicity.
Check with you local industrial electronics store. Step it up.
Been there done that.
Adger Smith (Former SS)
Old 06-10-2010, 01:45 PM   #6
buzzinhalfdozen
Liked 11 Times in 8 Posts
Where exactly does the starter wire go to? Seems odd that any switch would fail with such minimal usage. I use the 8000 ARC panel, touch pad which just supplies a ground to activate the relay, works great and very nice to install. Maybe check to see how many anps you're sending thru this circuit, Adger is right the switch rating may not be up to the task. I've had good luck with ARC stuff heck a buddy of mine has had the same panel in his car for nearly 15 years. Joe
Joe Buchanan SS/BX 3117
