Liked 120 Times in 11 Posts
All of a sudden my q-jet is giving me fits..... When I stage below 2600 rpm no problem, when I go above that to 2700 and up the secondaries open and push me in deep and it is like wrestling with an alligator at the starting line. Last year I could leave up to 3500 with no problem
I will accept all idea's here, pm, return reciept mail, telegraph or email. Very frustrating and distracting at the starting line. Can anyone HELP an old alter boy.
Joe DeMarzo 1317 STK |
Liked 1,874 Times in 422 Posts
Joe,
Are you staging with or without a two step? Have you made ANY changes?
Alan Roehrich 212A G/S |
[QUOTE=Joe DeMarzo;189885]
Can anyone HELP an old alter boy. Joe -- If I qualify call me .................
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO Last edited by Jack Matyas; 05-31-2010 at 11:43 AM. |
I have the solution, Joe. Put a stick in it! Lol!!!
Joe Martens AA/Stock 3969 |
Liked 110 Times in 29 Posts
Joe:
You know you can call me, right? I'm in the shop today. No rest for the weary. |
Alan, old footbraker, no changes.
Danny will call tomorrow, Joe, I would hurt myself with a stick, lol Enjoy the day.
Liked 4 Times in 1 Post
Maybe not the carb, but the rear brakes need adusting- if they are drums, or some other brake related issue.
Tony Curcio 1860 STK |
Liked 9 Times in 3 Posts
joe couldn't you just adjust the spring on the secondary flap a little stiffer?
Mark Markow 171 ss/tb |
Several things are possible.
As already mentioned, it could be brakes, however, it's not likely with your description, as less brake would mean less load. It wouldn't bring the secondaries in at a lower RPM, it would just push through the lights. It could be a converter problem, if the converter has failed and is tightening up, you need more throttle to get the same RPM, and it pushes harder as well. Or, the secondaries could have gotten looser, either from the spring getting soft or out of adjustment, or if you still have the choke pulloff, it could have gone bad. If the choke pulloff is there, and still hooked up to the secondaries, like it should be, it helps keep them OUT, unless it has failed, then it allows them to come in earlier. Check the carburetor, then in a safe area, do a flash test, just mat the throttle from a high idle and see if the converter still flashes like it did before.
Liked 460 Times in 91 Posts
I second that................
Bob Bender 144 O/SA 2010-2012 National Record Holder |
