Old 05-24-2010, 11:01 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Question Type F fluid and soft shifts
I recently switched to an ATI converter and in their instructions they require a type F fluid that is red in color. Prior I was running a TCI converter with a lower stall and the TCI green fluid and had a very firm shift. With the ATI with a slightly higher stall the shifts are not crisp at all. I am wondering if this could be due to the Type F fluid I am running or due to the higher stall or possibly a combination of them both.
I would like to try a different fluid to see if I can get a crisp shift again.
Any recommendations on which brand(s) of Type F that are red in color that work the best?
Thanks
Chad
Chad E532 is offline   Reply With Quote
