Liked 129 Times in 59 Posts
Pete,
10K sounds like a lot of weight for a 1/2T pick-up. You didn't mention how the truck was equipped (engine, trans, rear axle gear ratio), but most small pick-up trucks aren't rated to haul that much weight. There are a number of websites which list the Gross Vehicle Weight and Gross Combined Weight of the various combination's, and depending on how your truck is optioned, you might want to consider a heavier-duty truck. The air-bags are a good idea, but they won't help you when you need to stop! I've been using the Reese Load Equalizing Hitch and Sway Control for years and they work very well if not overloaded. Good Luck! Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 13 Times in 10 Posts
pete , 1000 bars and sway control a must for what you are trying to accomplish with the 1/2/ton pick up!!
Liked 93 Times in 52 Posts
Pete,
I have a Reese 14k/1400 tongue hitch # 63970. ![]() I pulled my 24' Haulmark (10k gvw) with a golf cart in the front and my 68 Camaro using a 2001 Z71 with a 5.3 and 3.73s for 2 years before getting a 2500 Dodge 5.9. You should have the biggest trans cooler on the truck as possible. I used the equalizer bars with no sway control. I had no other spring helpers. The equalizer hitch with the 1200 lb bars worked great. I only had issues with a head wind. Otherwise, put it in tow-haul and let er rip. I got about 8.5 mpg. Clark Doukas Last edited by cad; 05-18-2010 at 07:47 AM. |
Liked 798 Times in 212 Posts
Thanks everyone for your input.
I will certainly put the information to good use. Pistol Pete |
Liked 320 Times in 102 Posts
Hi,
These specs apply to a 2008 model year because that is the latest year that is posted and they should be similar to most current GM models..... Chevy Silverado/GMC Sierra, Light Duty, Crew Cab Shortbed Vehicle Engine Tow Limit (LB) 1500 CC Shortbed 2WD 4.8L V-8 4,600 (d) 1500 CC Shortbed 2WD 4.8L V-8 6,600 (g) 1500 CC Shortbed 2WD 5.3L V-8 6,600 (e) 1500 CC Shortbed 2WD 5.3L V-8 7,600 (g) 1500 CC Shortbed 2WD 6.0L V-8 8,700 (g) 1500 CC Shortbed 2WD 6.0L V-8 10,200 (g)** 1500 CC Shortbed 2WD 6.2L V-8 8,600 (e)* 1500 CC Shortbed 4WD 4.8L V-8 5,400 (e) 1500 CC Shortbed 4WD 4.8L V-8 7,400 (i) 1500 CC Shortbed 4WD 5.3L V-8 7,500 (g) 1500 CC Shortbed 4WD 5.3L V-8 8,500 (i) 1500 CC Shortbed 4WD 6.0L V-8 8,400 (g) 1500 CC Shortbed 4WD 6.0L V-8 10,500 (i)** 1500 CC Shortbed 4WD 6.2L V-8 8,400 (e)* Manufacturer’s note: Shortbed models are not designed or intended to tow fifth-wheel trailers. *Denali model. **NHT Enhanced Trailering Performance Package required. Key To Charts a = Automatic Transmission a4 = Automatic Transmission, four speeds a5 = Automatic Transmission, five speeds a6 = Automatic Transmission, six speeds m= Manual Transmission I-4 2,100 (g)/3,000 (g) b = 3.08:1 axle ratio c = 3.21:1 axle ratio d = 3.23:1 axle ratio e = 3.42:1 axle ratio f = 3.55:1 axle ratio g = 3.73:1 axle ratio h = 3.92:1 axle ratio i = 4.10:1 axle ratio j = 4.30:1 axle ratio k = 4.44:1 axle ratio l = 4.56:1 axle ratio n = 4.88:1 axle ratio o = 5.38:1 axle ratio AWD = All-Wheel Drive CC = Crew Cab KC = King Cab QC = Quad Cab SWB= Short Wheelbase LWB = Long Wheelbase DRW= Dual Rear Wheels CV = Cargo Van PV = Passenger Van RCC = Regular Chassis Cab SCC = Super Chassis Cab CCC = Crew Chassis Cab TD = Turbodiesel TC = Turbocharged SC = Supercharged NA = Not applicable, or not available t = Towing package required. x = Trailer brakes required. This info is available on-line at the Trailer Life web site... Have fun, Bob
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 05-14-2010 at 07:45 PM. |
