Old 05-13-2010, 09:48 PM   #4
Lapeeracing
Send a message via AIM to Lapeeracing
Default Re: radials vs bias on super stocker
There have been a number of threads on this and generally what the guys report is that the radials are worth .05 to .15 depending on the combo. What most are doing is saving the radials for qualifying or heads up runs-some, but not all. Personally I have not seen anything but it may be the way I run my car. For you, I would start with the bias and then the radials on a 1" wider rim than the bias. Hope this helps and good luck!
Lapeeracing is offline   Reply With Quote
