#11 |
Liked 2 Times in 2 Posts
Man it sure sounds like plugs.I know you changed them.Might try another set different brand. Also check for moisture/condensation inside the dist cap and the plug wire sockets.Do you keep the car outside?
#12 |
Liked 54 Times in 12 Posts
stay in enclosed trailer same as it did last year
#13 |
will i can say that it is not fuel problem.will try new coil and plug next weekend
#14 |
Liked 28 Times in 9 Posts
Pat Collins ( TechWest Racing Services ) is right on regarding loose or oxidized connections to the coil / MSD ; been there done that . It may not be the problem in this case , but is good advice for any racer.
