Old 05-01-2010, 10:26 PM   #1
GTX JOHN
Liked 2,486 Times in 697 Posts
Default Re: front end wobble???
Last time I had that problem on my Demon.......lower control arm bushings were really egg shaped from coming down hard on front wheels. You may be able to see them (arms) rubbing on K .member. Jack it up and check for looseness. While you are under there look at strut rod bushings too. Both common problems on Mopars. Call me if you need to know more.
PS got all your stuff gathered up
John Irving
Old 05-02-2010, 12:15 AM   #2
bdixon
Liked 15 Times in 7 Posts
How ya been? Going testing sunday with 72 340 a body, will drive this till mine is done.. found our wobble was bad drag link,
bdixon is offline   Reply With Quote
Old 05-02-2010, 12:16 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
You might also check all the connection points on the drag link for wear or being loose...
Adger Smith (Former SS)
Old 05-02-2010, 12:29 AM   #4
bdixon
thanks that was our problem got it fixed today thanks again bdixon
