#81 |
Liked 1,594 Times in 583 Posts
Drooze...next time you should consider Calico coated bearings.
You can buy them directly from Calico. http://shopping.netsuite.com/s.nl/c.573180/sc.2/.f I checked their website for availability, but it appears a lot of those Hemi's have been coming apart since they are out-of-stock... ![]() |
#82 | |
#83 | |
We are responsible for 50% of the DP Motor failures ![]() This one may come apart too....but the next....that one will stay up. To leave you a quote from Monty Python Quest for the Holy Grail. From the King in the Swamp talking to his son. "When I first came here, this was all swamp. Everyone said I was daft to build a castle on a swamp, but I built in all the same, just to show them. It sank into the swamp. So I built a second one. That sank into the swamp. So I built a third. That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle in all of England. " Thats kinda how we live our lives around here....it works, it may not be the easy route but it works....and we LEARN how to build damm strong castles. Were gonna have the fastest and strongest DP out there in spite of ourselves.....eventually ![]()
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
#84 |
learning how not to do something is as important as learning how to do it.
If you are at the track and you find out something doesn't work, it can help you as much as something that worked
Art Leong 2095 SS |
#85 |
So Chris, I take it your using the newly accepted Manley rods with the 5.7 OEM Diamond pistons?
Jerry Williams NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's. |
#86 |
Yep....and some additional head gasket layers.....length is a bit long.
#87 |
Yup. That bit long was one of my concerns all along. The OEM Scat rod @ 6.20" center to center compared to Manley's approved 6.24" connecting rod now put's your 5.7 OEM Diamond zero deck piston's .040" out of the hole. If my math fiqures out correctly, you'll now need a .066" head gasket for your 5.7 to be legal. Factor in the additional .040" head gasket thickness and you now have a missmatch between your intake and head port. Stick a boroscope down one of the intake runners and you'll see. Wouldn't be a problem if you could alter the port missmatch with a little grinding. Also, by moving the head further away from the block will create new problems with lifter preload if your still using OEM pushrod's which may (?) lead to valve float @ rpm. Plus your .035" bearing clearance has me worried. Afterall, your not building an aluminum rod motor. I don't know if your oil pump can keep up with that, plus the oil flow deadheads at the lifters. Catch my drift?
I felt the need to post this cause most times when we talk, you always seem to be in high gear when I'm just starting to get off the line. I get confused easily as you can tell. Must be my age. lol
Jerry Williams NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's. Last edited by hemidup; 04-09-2010 at 11:22 PM. |
#88 |
Liked 880 Times in 311 Posts
Drooze,
The way I've always read the rule books a Stocker engine has to be built by blueprint specs. I'm of the opinion you can't just stack up .066 gaskets to get piston to head clearance and be legal. There have to be some specs on the engine as to piston above the deck or below the deck. The way tech has treated me is if the spec calls for below the deck it can be at zero deck and below, not above. If it calls for above the deck it has to be above the deck. What gives? Are you just throwing out all the rules and doing as you please or is someone letting or telling you to overlook the rules becaue you are a DP owner? Are you posting on here how you are building an engine that won't get through tech? I think that would be the last thing I would be posting.
Adger Smith (Former SS) |
#89 | |
Adger is correct. I have read many of your posts and although you may have some experience with motorcycle and car engine building, a legal engine for Stock or Super Stock takes a bit more of not only knowledge, but also experience. |
#90 | |
Jerry Williams NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's. Last edited by hemidup; 04-10-2010 at 12:28 AM. |
