#1 | |
Straight from the rule book. Pure Stock These classes are for street type cars which have minor modifications to the engine, chassis, transmission, carburetor, etc., unless it is specifically stated that a modification or optional equipment is permitted. No turbo or super charged cars allowed. A through I are the only available classes, with the same class breaks as stock, "Class weight breaks and indexes are for both stick and automatic". Numbers must be at least 4” high on all 4 windows. CLASS WEIGHT BREAKS FOR STICK AND AUTOMATIC: A/PS ....................8.00 to 8.99 B/PS ....................9.00 to 9.99 C/PS ....................10.00 to 10.99 D/PS ...................11.00 to 11.99 E/PS ....................12.00 to 12.99 F/PS.....................13.00 to 13.99 G/PS ....................14.00 to 14.99 H/PS ...................15.00 to 15.99 I/PS......................16.00 to 16.99
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock |
Battery up front, Water pump and alternator must be driven by crankshaft. Headers permitted ,but must run mufflers that do not go straight threw. cannot uncap headers,Stock type fuel pump must be used.one electric pump allowed when used through stock mechanical pump.you may remove other drive belts such as power steering ,a/c ,ect............. and there is more rules listed on page 63 of the 2010 IHRA rule book.Should be able to go on line and find these rules.
Danny Waters, Sr / 73 Duster "340" |
Liked 1,002 Times in 203 Posts
no hoosier radials allowed because they say 30" on the side wall desigination!! tires must say 29.5 or smaller.
Guest
Posts: n/a
Great class, IHRA Pure Stock engine rules are pretty much the same as NHRA stock engine rules were in the 80's before things started to become "unstock".
Be careful on your cam and springs too.
Liked 5 Times in 3 Posts
M/T makes a 29.5x9 that is legal! Truman got M/T to make them
Liked 3,252 Times in 989 Posts
Does the 80 Volare with 360 have the same 185/289 rating as does NHRA? Would weigh 3345 for G and 3490 for H in NHRA.
May be a question for Danny Waters but anyone who knows the answer I'd appreciate it.
