Liked 70 Times in 29 Posts
just depends on how "stock" your "stocker" is.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 325 Times in 50 Posts
In SS/IA you are @ 3355 lbs, in SS/JA you are 3525 with the 5.7. The car is a natural SS/IA car so you can run H, I, or J. 3070 lbs for SS/GA. All weights include driver @ 170 lbs
Jeff Teuton 4022 STK Last edited by Jeff Teuton; 03-22-2010 at 04:02 PM. Reason: Added Something |
Just to clarify Jeff's numbers.(you got to rember that he is a car salesman!)
Challenger with 5.7 is 305 SS hp with a 3100 shipping weight. Its power to weight factor is 10.16, which makes its natural class as SS/IA 10.00- 10.99 IA=10 x 305 hp + 170 driver= 3220 min weight 10.70 index. cage, license, net, trans sheild,& 3.2/5a pants and jacket required Can also run HA @ 3065 min weight(9.5x305+170) with 10.60 index Can also run JA @ 3525 min weight(11x305+170) with 11.00 index. No cage,license,net,.Trans sheild is required. Must have 3.2/1a pants and jacket You can also run SS/GT. GT/DA is(9.5x305+170) 3065 min wt with a 10.50 index GT/EA is (10x305+170) 3220 min wt with a 10.65 index GT/FA is (10.5 x305+170) 3370 min wt with a 10.80 index All of these GT classes require cage,net,sheild,license and 3.2/5A pant and jacket Last edited by Just Observing; 03-22-2010 at 08:04 PM. |
#4 | |
The cage we had certed, good to 8.50, the Pants and Jacket (hood gloves and stuff) all 3.2/5a, Net (RJS), Shield (CSR) and liscence, Super Gas, and Stock. I think it will all depend on the testing....well go from there. Thanks, its nice to see it all wrung out by someone else and get confirmation its right ![]()
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
#5 | |
Also you might consider # of cars in class(es). Too many would make the chance of a heads up greatly increase. I would consider a stocker to be at a disadvantage in a heads up with most purpose built SS or GT cars. |
#6 | |
Thanks, good advice
Unless the rules have changed in 2010 (haven,'t download Rulebook), you have always been required to possess a Competition License to run SS/IA. This requires a medical exam then followed by testing in car. I did not notice in your posting that you had obtained the above license......you might want to check into that. I believe that the transmission blanket is only required when you are running 10.99 or faster no matter what record is as long as index is 11.00 or slower. Those are the reasons I always add the required weight to run SS/JA (can't fog mirror hardly --Let alone pass Med. Exam). Real Super Stock guys could probably elaborate on this further
Bone Stock 2009 Challenger DP
![]() Im "on the fence" about running it I or J, 3355 is about where its at with me in it and leaving the Accumulator in, as well as putting a few "Oem" I can make 35xx legally with weight and the replacment of some OE items that I found lighter conterparts for and were legal to replace, I just dont know if I feel like doing that work. Im thinking ill take the parts along for the ride and depending entirley on how it runs out in testing Ill make a decision. Jeff can you run KA ? No record there ![]()
