You were inefficient with your clutch, running 4 tenths slow compared to your MPH (1320 / 133.29 = 9.90 ET). Now you have a PG that is running right on the formula (1320 / 129.43 = 10.198). See? Proof the formula works.
Now you are down 4 MPH because you took out the manual transmission. Your not going to get the 4 MPH back unless you ad more HP to the engine or get the weight down or make the Vega more aerodynamic. Another 50 HP or so should get you your 4 MPH back.
Jeff Lee 7494 D/S '70 AMX |
#2 | |
6.46 x 1.57= 10.14 Should I be working to get into the teens at that mph or is it not possible? |
for 1/8th mile just alter the formula to 660/MPH = ET
I realize you didn't have the clutch "optimized". That can be difficult on a dual purpose car, too many compromises for street duty. The MPH loss is just a fact of life when going from a manual race trans to a PG. You would spend a ton of money on an automatic trans to get that MPH back; and I'm not sure it is possible. Dropping 4 MPH & only having 1 shift is like going down the track in slow motion, huh?
Jeff, I found some HP. DA was -2022!! How about a new best 10.08 at 130.87 with a bad 1.42 60'. It turned the tire a bid. Not bad for a street car.
