Liked 5 Times in 5 Posts
1980 chev 305, 416 head, stocker, which intake makes the best power?
14014432-aluminum 14014440-cast iron 14057055-cast iron 14057053-aluminum Thanks guys.
6535 stk 81 Malibu K/SA |
Liked 5 Times in 3 Posts
I would use 055....but what do I know.....
Liked 7,781 Times in 1,743 Posts
The most expensive one!
Liked 10 Times in 6 Posts
Dave , I use the 055 intake on my 1981 malibu, you can`t use the 053 on 80 or 81. Tom
Tom Moock 5704 STK |
Liked 12 Times in 4 Posts
I just looked at the blueprints specs again because I have 053 for mine and got worried I had made a mistake. But it is listed as an alternate manifold for the 305. That's the manifold several really good engine builders told me to use. JMT.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.” - Aristotle |
I had the same Question and spent money to find they are virtually identical. That is if the iron one wasn't very heavily rusted. ...Thanx Trevor
Thanks to the guys with helpful responses and the guys who PM'd me.
tj310, do you mean you found the 055 and 053 to be the same performance wise?
Any experience with a 440 vs a 432?
Liked 112 Times in 31 Posts
The CAST IRON one that weighs the same as the ALUMINUM one is usually the BEST one.
Jerry |
We have only run the aluminum on the car, I was refering to flow bench numbers...Thanx Trevor
