Liked 886 Times in 238 Posts
Weight vs. wallet, and/ or skill level. .........1 5/8....083 CM 1.5 # per foot .....ERW .1 5/8 .134 wall 2.13 # per foot. ............30 % weight savings regardless of number of points of attachment ,all things being equal ........And oh by the way about double the price just for materials,not counting additional time / skill for fitting and welding. ......I just compleated a '56 Chevy Gaser with a S&W ERW cage fit perfectly and the pre notching was very close. ......I TIG all my cages and the .134 tube welds ok , but takes quite a bit more heat. ......Tom
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 03-14-2010 at 01:20 AM. |
Liked 4 Times in 4 Posts
I've used S&W ever since I bought my first roll bar and they have always fit right. Find a good race shop to install it for you to avoid any problems with tech.
JimR
Jim Rountree |
Liked 54 Times in 7 Posts
I installed a S&W kit in my '77 Camaro last winter and it was so easy it was fun to install. The tubes were bent perfect and only minor trimming was needed to fit them in. I will use there kits on any project in the future and highly recommend them to anyone who asks!
No one makes anything for my car (86 Chrysler 5th Ave.). Measured cars @ Brown County, found '74 Duster same interior size. Ordered a 10 point kit from S&W, had local Indy Car fabricator here in Martinsville install it. Fits well. David.
I understood that most of the roll bar kits that are sold are three sizes fit all. if your car is the right size it works great if not it winds up a terrible fit.
This is not the case with S&W their stuff ios made specifically for the car. So it always fits.
Art Leong 2095 SS |
Thanks for the recommendations guys. I spent a good amount of time speaking with a local fabricator. He's going to custom bend me an 8 point roll bar, also he's going to make the down bars that will allow me to retain the back seat. As well as supply me with the subframe connectors and a driveshaft loop.
It's Jeff Blevins, Checkerd Racing, out of Bedford, Indiana. It's a mild steel roll bar, 1 3/4 x 0.134 tubing. Pricewise he's very competitive, as in he's about the same as a Jegs or an S&W kit sans shipping. In addition, I'm supporting someone local. Once I start installing it, I'll know how good/bad my decision was.
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock |
Liked 11 Times in 8 Posts
You should have no problems, I like to bend my own personally, however I've used a few S&w bars and they fit fine. Never used Jegs stuff however anyone with some experience bending up tubing should be able to fit a hoop quite nicely, I like to keep things tight to the car, however it adds time to the build due to welding access. Good luck with the project.Joe My pick is always CM as you save weight, and it goes a long ways if or when you sell the car.
Joe Buchanan SS/BX 3117 Last edited by buzzinhalfdozen; 03-14-2010 at 07:56 PM. |
