Old 03-10-2010, 08:01 PM   #2
Robert Swartz
Robert Swartz's Avatar
Default Re: What gear for my 307 Cutlass
Originally Posted by Poke View Post
I will be running a 307 olds motor with a 4500 stall and a 28" tire was just curious what you guys would recommend for gears???? Probably be some where around 3400lbs
First we need to establish a couple things.
Are you going to drive this car on the street?
Is it strictly a race car?
If you plan to drive it, you don't want a killer gear. If I had a similar car to this and planned to strictly drag race it. If it's pretty much a stock engine, you have a healthy converter and a small rear tire. A stock engine is going to peak out at about 55-5600 rpm. For a 1/4, I wouldn't run anything steeper than a 4.30. If it's an 1/8 car, you can go much steeper, you could easily run a 4.88-5.13, you'll still max your rpm out by the end of the run.
Just my.02
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
