Liked 4 Times in 1 Post
Hey, guys. My project is a 1976 Firebird with a 400. I am building it for NHRA Stock and i want to run a 4 speed. At this time, a Jericho is out of the question so what is my best bet? Super T10? Thanks for the help.
Spend the extra for a Jerico, it will pay for itself in the end
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Liked 165 Times in 59 Posts
if your going to run a stick you need to go with a good trans ,jerico,liberty,but depends how resourceful you are you mite be able to find a doug nash five speed that is converted to a four speed but finding gear ratios will be a challenge to find ,,strong but old
gmonde |
Liked 497 Times in 115 Posts
You car is only as strong as the weakest link. The T10 would be the weakest link.
68 Chevy11 327 F/S |
Liked 5,117 Times in 1,949 Posts
Your problem won't be so much the trans , but rather ,the clutch.
Too much weight, not enough hp and rpm to use counterweights effectively. I f you can't afford a Jericho, I'm going to assume you won't be able to put a good clutch in it either. You CAN find an old Doug Nash 4+1 with about a 2.96 low and it will be strong enough, but remember, a 1 to1 4th gear, is still driving through the cluster. You 'll have some loss there. Bottom line though, is, and trust me when I tell you this (been there, done that) , this whole deal is a bad idea. I would advise you to not do this.
Liked 2 Times in 2 Posts
What whole deal is a bad idea? Running a stick or building a stocker?
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#7 | |
