#8 | |
Check and I understand all that, on the cars (vs their Street cousins) I can adjust my supply pressure with a regulator after much finer than in a closed loop system, there I need to modulate the pump (as the St units do) to maintain a constant pressure.
That was why I was curious as to how hes modulating the pump for contant and steady pressure, obviously a WOT burst will cause a drop in the line pressure, then the electronics have to say Oh **** run the pump, there is a delay and a POTENTIAL for inconsistent pressure. Without being able to bodulate and control pressure exactly your not going to be able to gain constant and reliable atomization when these (the SRT 4) injectors atomize best at a given pressure on the DOT. Now granted thats not where theyre supposed to run but its where the spray patten is best (I saw just this on a fuel test bench) and its common knowlede (supposedly) with the SRT guys. Soooooo If you can see that thats push lok line and not rubber hose your eyes are better than mine (and thats not suprising as Im blind as a bat) but what is obvious about the Mecum car is its a hack all the way around AT LEAST when those pics were taken. Also fluid to fluid friction can cause cavitation and bubbles as well, BUT even knowing that I still ran my return line in the bottom , why ? Because it looks better and will cut down on aeration.....I can change it later....I also unlike many others opted for a check valve before the rail to hold line volume....didnt have to but I could and its right so I did.... (no making fun of my lines I hadnt finished moutning them ![]() ![]() Quote:
