Old 12-30-2009, 11:17 PM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 879 Times in 236 Posts
Default Re: Burnout?
Three speed transmissions should only use 2nd and high in the water. .....the sprag ,or over running clutch in a three speed can be damaged when shocked in the water. .....Other than that , shift away ! ......Tom
Old 12-31-2009, 07:45 AM   #2
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
I would think with basically no load the burnout would be easier on the trans than the actual shifting going down the track.
Floyd Staggs 787 SST
Old 12-31-2009, 09:23 AM   #3
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Several years ago I was at West Palm Beach and Roy Hill was down there with his Pro Mod car. He was parked about 50 feet from where I was parked and because I drive Fords he came over and we talked a while. I guess he had a little interest in what I was doing and later after a run he came over and told me I was doing my burnout wrong. He said that most people do. He said that all I needed to do was, in his words, make them round and dry. He also said with a glide do a high gear only burnout and not do it as hard as you see most people do. Starting in high gear has the wheel speed up right away. I started doing my burnouts that way and have been doing them that way ever since. I saw that weekend after doing it my car started being more consistant in 60' and I get great life out of a set of slicks. The harder the burnout, the more of a temperature change in the tire, which over time will change the compound of the tire. I hope this info helps.
Chuck
C and W Racing is offline   Reply With Quote
Old 12-31-2009, 07:46 PM   #4
Chris Williams
Chris Williams's Avatar
Chuck, Jack Beckman taught us the same thing, and that's precisely what we do as well.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 12-31-2009, 08:30 PM   #5
Floyd Staggs
I guess I been doing it wrong and better change.
Old 01-01-2010, 10:33 AM   #6
Rick Blake
Rick Blake's Avatar
Frank Hawley suggests the same procedure
Rick Blake 2395 SG, SC, SP
Rick Blake is offline   Reply With Quote
Old 01-01-2010, 07:17 PM   #7
Tom Goldman
I will continue to do my burnouts " incorrectly" ....I shift immediately into hi and come out of the water at 7500 rpms with a smile on my face you could'nt knock off with a 2x4 !!....Oh, by the way, my 60' rarely varies by more than .001-.002 .......... Not that the "Professional Instructor" method is wrong or right, do the burnout that works for you. .......Some of the most successful Sportsman racers "melt the tires off" ,and are still deadly consistant.......Do the burnout that works best for you and your car. .....Tom
