Old 12-30-2009, 05:05 PM   #1
Ty Webb
Default Re: ahfs question
It should count for AHFS at alt. tracks based on alt. index. The factor is good enough for records, it should be good enough for HP. Competition Eliminator can get their indexes hit at altitude tracks based on alt. indexes, S/SS should also.
Ty Webb is offline   Reply With Quote
Old 12-30-2009, 08:03 PM   #2
RPinoski1
Wink Re: ahfs question
I agree 100%.
Besides everyone knows that a big block isn't affected nearly as much as the small block at altitude. Right?
RPinoski1 is offline   Reply With Quote
Old 12-30-2009, 09:48 PM   #3
Shawn S.Kvaas
Ty the comp cars don't get hit during qualifying.
Shawn S.Kvaas is offline   Reply With Quote
Old 01-01-2010, 11:46 AM   #4
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
It's sad that so many people know so little about the rules they race under.
Bob Mulry 7516 STK
A & M Motorsports
Old 01-01-2010, 06:17 PM   #5
JRyan
Liked 112 Times in 31 Posts
Ty,
Do you know that if you run 1.25 under the altitude factored index for the record, that you don't get the record at 1.25 under? It's LESS than that, and it varies dependant on which altitude track you set it at and the correction factors applied when it's factored back to sea level. So then it really isn't a 1.25 under run, and shouldn't be the cause of a HP factor. But we have no clarification on that either!!
The fact that NHRA personel previously had to do a bunch of paperwork to figure this out at altitude tracks is the reason they just let altitude factored runs go until now.
Jerry
Old 01-02-2010, 09:47 PM   #6
Pvt Parts
Pvt Parts's Avatar
Wait a minute. It seems that everyone is getting caught up in the emotional part of this discussion and speculation. The answer is right there in front of you. Strip away all of the B.S. and political nonsense and read the words.
The decision to adjust horsepower or to reduce the index will be at the discretion of the NHRA Tech Department
End of story. Everything else is secondary and irrelevant. Plead your case but in the end it's their decision.
Old 01-02-2010, 10:51 PM   #7
Liked 5,146 Times in 1,964 Posts
That sentence alludes to an either/ or situation, not some arbitrary decision.
No wonder you're still a Private. Get back in line, soldier
Old 01-08-2010, 06:08 PM   #8
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Has anyone done a spreadsheet of this for the various tracks that could take the records list and autocalc it across ?
If its sounds like something that someone else would like to do/see but dosent know how, I know how to do the excel part I just need someone to check/verify a couple of the calcs as well as be 100% sure Im putting the right info into the sheet.
PM me if youd like it, personally Id like a list of all the records and what has to be run where to beat them on alt factors.....I like it all laid out in front of me....
Cheers
Originally Posted by JRyan View Post
Ty,
Jerry
Chris "drooze" Wertman is offline   Reply With Quote
Old 02-11-2010, 03:24 AM   #9
Tom Moock
Liked 10 Times in 6 Posts
Anybody known the answer? Altitude tracks at national and division events, 1.25 under altitude index or 1.25 under sea level index ? AHFS Can somebody ask at the Winternational`s? Tried to call Bruce no answer. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
