Old 12-29-2009, 11:24 AM   #7
Pat Cook
Default Re: Cylinder Sleeves
Maybe I should talk to my machinist Kip Martin, I am sure he can do the hone deal on cylinder sleeves, and he has a lot of experience with 390 Fords. The last time it was put together we used a low tension ring package from Total Seal. The engine has about 30 passes and has developed a lot of blow by when it is idling, more than it did when it was first put together. I don't think it would have wore the cylinders in only 30 passes?
Or maybe I just need to put the "PVC stock eliminator crank case evac." system on it?
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
