Seeking information and feedback on racing jacks(service jack).
Interested in a light weight,low profile jack.suitable to take to the track.any suggestions would be helpful.thank you. |
Liked 26 Times in 13 Posts
I recently bought a Torin aluminum 1.5 ton jack from Northern Tool. So far, so good. Light and easy to handle and is pretty low to get under the front end. I would like it to have more lift height, but other than that it is a lot easier to use than my old 3 ton steel monster that leaked down too much. Northern has a pretty good selection of jacks of all sizes shapes and colors. www. northerntool.com
Bill Harris ex 2172 STK ex 2272 S/S |
Liked 14 Times in 11 Posts
Harbor Freight has about 4 different versions of a aluminum light
weight "racing" floor jack. Most weight in at 45lbs or less. From other guys I have talked with, they recommend buying the most expensive of the 4 versions at about $150 before any discounts or sales. My normal cast iron "costco" floor jack weights closer to 100 lbs so I am also planning on buying a light weight unit for taking to the races.
Phil Saran Parker, Colorado |
Liked 2 Times in 2 Posts
I bought a aluminum jack from Harbor Freight about 5 years ago thinking if I got a couple of years out of it,OK.I've had it 5 years now and it still works great.Even lifts my '02 Dodge quad cab.
Nautilus Racing |
Liked 33 Times in 17 Posts
FYI: There was a discussion here about a year ago on this subject. The concensus was the 1.5 aluminum Craftsman was not a good buy but the 2 ton Craftsman was a good jack for the money.
