Old 12-16-2009, 11:42 AM   #1
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Default Which damper for a 327 / 275?
I'm making out my Christmas list, and have a question for you guys...ATI shows a 6.325" and a 7" balancer for the SBC. I've never understood why, but never really needed to know til now.
Paul Merolla is offline   Reply With Quote
Old 12-16-2009, 06:47 PM   #2
rod
Liked 20 Times in 15 Posts
Default Re: Which damper for a 327 / 275?
bigger, larger dia. is better. if you have a Jessel belt system, you can use an 8" narrow width, not the wide 8".
rod
rod is offline   Reply With Quote
Old 12-16-2009, 07:57 PM   #3
Liked 1,952 Times in 439 Posts
Call ATI and let them tell you exactly what balancer you need. Their balancers are tuned, by any number of factors. They offer multiple diameters, various numbers and locations of o-rings, different materials for different weights, and even different durometer o-rings. All so you get the damper that works for what you are putting it on.
Old 12-18-2009, 11:31 AM   #4
Aaron Keown
Aaron Keown's Avatar
The smaller balancer will run faster on the car,larger one will make a smother engine and show more h.p. on the dyno but will not accelerate as quickly.You might also want to think about ATI's balancer that has the magnets already built into it for the crank trigger,if you already have a crank trigger just be aware that some machining will be required around the inside lip of the crank trigger wheel to make it seat properly,this did not used to be the case but they have changed the lip on the balancers within the last year.Its only an issue if you are using a crank trigger.
Aaron Keown is offline   Reply With Quote
Old 12-19-2009, 09:33 AM   #5
Paul Merolla
Thanks for the replies, guys. Aaron, I forgot to say this is for a stocker so no crank trigger.
Old 12-19-2009, 09:36 AM   #6
Paul, if it helps you decide, we have the smallest aluminum damper ATI makes on the 427 Stock engines we race. And we do not use those heavy flexplates either.
Old 12-19-2009, 06:36 PM   #7
Bub Whitaker
ATI 917320 for that combo...
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 12-20-2009, 08:45 AM   #8
Paul Merolla
Thanks, Bub, for the reassurance. I was told by reliable sources to get the lightest one, and that was the # I came up with from ATI's website. BTW, anybody else that's shopping for one of these...Summit beat everyone else by $50.
Old 12-20-2009, 11:56 AM   #9
Mark70Nova
Thumbs up Re: Which damper for a 327 / 275?
I'm a WD for ATI dampers and would be glad to help out any of you guys. I'm with Alan, as I prefer to put the small light weight ones on our drag race engines.
Mark
Mark70Nova is offline   Reply With Quote
