Liked 333 Times in 180 Posts
I used aircraft carpeting---you hold it up to the light and you can see thru it---very light weight stuff ---took it to an auto upholstery shop had them put edging on it and snaps so that we could access the trans tunnel to do clutch work and trans removal---was not that expensive and held up well--- you can vacuum it to clean the interior of the car---look into it!!!---Comp 387
