Old 11-14-2009, 07:09 AM   #8
THE LEGEND
Default Re: Alcohol question
Take out foam.
Another trick for milky oil. Run it Hot. I always get mine to 200 before I park it helps evaporate the water. I ran alky this season in my dragster. I changed oil twice. I probably could've went longer Oil looked fine. Also AMSOIL makes a racing synthetic for Alky engines.
Be careful with the Smelly additive it can gel in your fuel system.
If you sit for more than a week spray carb with wd40 keeps it from sticking.
Alky is corrosive and will wear out your engine parts quicker than normal.
One more thing. The old story about Alky being more consistent is a myth. Especially if your gas carb is set up correctly.
My gas car is just as good as my alky one. Next season I'm switching one of them so I don't need to carry both fuels.
Chip
THE LEGEND is offline   Reply With Quote
