Liked 354 Times in 120 Posts
Been torn down about 20 times, they use a caliper in TDC indicater. Rock it on the bottom of the stroke set to zero then rotate it up you will then have your stroke. They check deck hieght plus gasket as long as you are more than the spec you are ok, I run about 35 on my 283 you may want a little more on the 327. Tom
Tom Meyer 5240 SS Stock ??? |
