Old 09-21-2009, 09:34 AM   #1
R. Thorne
Liked 101 Times in 34 Posts
Default Carpet Suggestions
Where is the best place to purchase lightweight, inexpensive carpet? Thanks, Ron.
R. Thorne is online now   Reply With Quote
Old 09-21-2009, 09:46 AM   #2
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: Carpet Suggestions
if you are using it in an automotive application ---go to a full service auto upholstery shop and ask about Aircraft carpeting ---if you do put it in make sure you hem the edges and put edging on it otherwise the stuff will come apart/fray REAL easily---this stuff is so thin you can see thru it no problems at all and probably weighs 1/4 of what regular auto carpeting does---any other ??? get back to me--comp387
Old 09-21-2009, 06:58 PM   #3
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Carpet Suggestions
speaker box carpet works well also. but not very durable either, just use a floor mat.
Mark Markow is offline   Reply With Quote
Old 09-22-2009, 06:54 AM   #4
Owen S Quirion
You can order a custom molded light weight carpet from Auto Custom Carpets (ACC), I think they are in Georgia somewhere. They will mold it without any of the backing or sound deadening materials. I saved around 20 pounds.
BF/S 1985 Grand Am 3.0 V6
Owen S Quirion is offline   Reply With Quote
Old 09-22-2009, 07:17 AM   #5
FED 387
we did a 67 camaro all the way up included the area where back seat was removed do not think we had anywhere close to 20 in the whole job--comp 387
Old 09-22-2009, 07:27 AM   #6
art leong
I used stuff I bought in Pep boys. Cheap, Very light and doesn't look to bad.
Art Leong 2095 SS
Old 09-25-2009, 12:09 PM   #7
R. Thorne
Thanks, guys, for the suggestions. Got some at Pepboys(9ft x 6ft for $30.00) that should do the job. Ron.
Old 09-25-2009, 10:49 PM   #8
art leong
It worked for me. Needed 3 rolls though.
Art Leong 2095 SS
