Old 09-11-2009, 05:50 AM   #1
Notch1320
Default Re: Fuel rails??
Where in the rule book does it say you can't run an aftermarket fuel rail? I have seen them on numerous cars, including mine without issue???
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 09-11-2009, 09:28 AM   #2
west coast
Liked 227 Times in 74 Posts
My car is a FI car with stock rails. I have seen plenty of cars with aftermarket fuel rails I thought this was legal. Page 105 under fuel injection first sentence is Fuel injection must retain OEMthrottle body(s), plenum, and manifold. So that sounds like everthing else you can change Rails, pumps, regulator, take the pump out of the tank to use a fuel cell. The rest of the section talks about larger fuel injectors and the system open or closed loop. Does anybody see anything else or is my interpitation off base. Thanks
west coast is offline   Reply With Quote
Old 09-11-2009, 09:49 AM   #3
larry dowty
Liked 11 Times in 4 Posts
I had lunch with tom turner yesterday, and then read his post later, i know he knows the rule book inside out BUT i think he is wrong this time????
larry dowty 6388 SS
larry dowty is offline   Reply With Quote
Old 09-14-2009, 06:55 PM   #4
Tom Turner
I guess that I need to carefully read the CURRENT rulebook more carefully. When we started with FI cars and then the FI classes; stock rails were required. That portion of the rules seems to have been deleted somewhere along the way. Sorry. TT
Tom Turner is offline   Reply With Quote
