#11 |
Liked 306 Times in 103 Posts
That's what Coan told me said you couldn't shift from high to neutral without trans not trying to swap
directions on intermediate drum not mention how many cars have been crashed by getting put in rev by accident most had rev lockout but got past somehow.Coan has clean neutral on some trans I've seen where has a second neutral past high gear {rev. pattern} Mike Taylor 3601 |
#12 |
has anyone ever compared the A1 pro-flites (or whoever makes them now) with the coan XLT 350?
#13 |
Liked 215 Times in 86 Posts
I thought the top stock Coan 350 xlt with double " N " shift pattern was designed / built so you could shift into " N " in the shut down and click off the motor ? Looks like a nice piece but I don't no anyone who runs one or how many runs you can get out of one ? Did call Coan and what did they say ? .....
#14 |
Liked 11 Times in 8 Posts
My trans has the "clean" nuetral, that's not an issue just can't keep intermediate clutches in it.I'm hoping that the latest "fix" is the cure. Now I've been told that adding the third disc is going to slow me down, I'm not really grasping the idea however I've been told this by a few trans guys. Since I still have clearence in my clutch pack I'm unable to understand how this is going to slow me down. Can someone explain? Joe
Joe Buchanan SS/BX 3117 |
#15 |
That's right clean neutral is to shut down in neutral without trans damage or risk of accidently shift
in reverse. Joe, sounds like one of those problems ''nobody else'' has had I've been there before I don't know you but from reading you're post/replies for awhile I say you have the abilities to figure it out. You may air test piston in drum thats giving trouble see if releases as quick as others or you can stack assm.of drums like trans was together,except outside of case and apply air through pump passages and check how things are working.I found problem in 350TH that way once.I also used mitchell manual told when this was applied for this gear that was applied for that gear etc.could help track down problem. Mike Taylor 3601 Last edited by Mike Taylor 3601; 08-31-2009 at 11:58 AM. |
#16 |
Joe , adding the 3rd clutch disc to the intermediate pack may not slow you down . You may not have enough points of contact/clutch suface area and is a possible answer as to why you are burning them up or driving through the clutch pack . I like Mikes idea on the bench test with pressure regulators . Or at lest fluid psi gage on the trans case to make shore you got the pressure you need . Its not enough clutch or not enough pressure .Good luck Joe let us know what the fit was . Ken R
#17 |
Well as I suspected the 3rd disc did not slow the car in fact it made some of it's fastest runs ever. We have 7 runs on it so far I'll let it go to 25-30 then tear down for inspection. Did not notice any ill effects from the clutch pack rearrangement, hopefully it will look good at tear down. Joe
#18 |
We had the same problem with our XLT. Added third clutch and now it looks like new after 100 runs. Also removed the O-rings from the steels.
Phil Unruh 52 SS/EA |
#19 |
Pro Trans makes a very good turbo 350.
#20 |
Yeah I know, when I was calling about trans my first call was to them however the very long lead time made me look elsewhere. My logic was if it takes that long for them to build me a trans what about parts and service from what I've heard basically neither is required. So it's my own desire to quickly get a trans that landed me where I am. However I believe I have it figured out I guess some more runs will tell the tale. Joe Oh and thanks Phil hopefully I will have the same results.
