Old 08-30-2009, 06:51 PM   #1
J Simoneaux
Default Re: Coan turbo 350 XLT
has anyone ever compared the A1 pro-flites (or whoever makes them now) with the coan XLT 350?
J Simoneaux is offline   Reply With Quote
Old 08-31-2009, 11:07 AM   #2
ken robinson
Liked 224 Times in 87 Posts
I thought the top stock Coan 350 xlt with double " N " shift pattern was designed / built so you could shift into " N " in the shut down and click off the motor ? Looks like a nice piece but I don't no anyone who runs one or how many runs you can get out of one ? Did call Coan and what did they say ? .....
Old 08-31-2009, 11:36 AM   #3
buzzinhalfdozen
Liked 11 Times in 8 Posts
My trans has the "clean" nuetral, that's not an issue just can't keep intermediate clutches in it.I'm hoping that the latest "fix" is the cure. Now I've been told that adding the third disc is going to slow me down, I'm not really grasping the idea however I've been told this by a few trans guys. Since I still have clearence in my clutch pack I'm unable to understand how this is going to slow me down. Can someone explain? Joe
Joe Buchanan SS/BX 3117
Old 08-31-2009, 11:38 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
That's right clean neutral is to shut down in neutral without trans damage or risk of accidently shift
in reverse. Joe, sounds like one of those problems ''nobody else'' has had I've
been there before I don't know you but from reading you're post/replies for awhile
I say you have the abilities to figure it out. You may air test piston in drum
thats giving trouble see if releases as quick as others or you can stack assm.of drums like trans was together,except outside of case and apply air through pump
passages and check how things are working.I found problem in 350TH that way
once.I also used mitchell manual told when this was applied for this gear that was applied for that gear etc.could help track down problem.
Mike Taylor 3601
Old 09-06-2009, 10:01 AM   #5
ken robinson
Joe , adding the 3rd clutch disc to the intermediate pack may not slow you down . You may not have enough points of contact/clutch suface area and is a possible answer as to why you are burning them up or driving through the clutch pack . I like Mikes idea on the bench test with pressure regulators . Or at lest fluid psi gage on the trans case to make shore you got the pressure you need . Its not enough clutch or not enough pressure .Good luck Joe let us know what the fit was . Ken R
Old 09-08-2009, 06:55 AM   #6
buzzinhalfdozen
Well as I suspected the 3rd disc did not slow the car in fact it made some of it's fastest runs ever. We have 7 runs on it so far I'll let it go to 25-30 then tear down for inspection. Did not notice any ill effects from the clutch pack rearrangement, hopefully it will look good at tear down. Joe
Old 09-09-2009, 08:31 AM   #7
69ssea
We had the same problem with our XLT. Added third clutch and now it looks like new after 100 runs. Also removed the O-rings from the steels.
Phil Unruh
52 SS/EA
69ssea is offline   Reply With Quote
