Old 08-06-2009, 06:39 AM   #7
Jim Bailey
Liked 584 Times in 94 Posts
Cool Re: Cross Ram Questions
Kevin, Brian Ebert (High Tech in Min.) and myself worked on this problem one whole afternoon on the dyno. I use the Programable MSD Digital Ignition, that allows you to vary the timing from Cyl. to Cly. I ended up with 39 degrees Total Timing in cyl.1, cyl.2, cyl.7 and cyl.8. I run 38 degrees in cyl.3, and cyl.6. I run 37 degrees in cyl.4 and cyl.5. This pretty much equaled out the egts.( I just saved you $300.00 in dyno time, laughing). Then, a quick run to a chassis dyno will allow you to fine tune the carbs. Forget about the mettering rods! They don't do *****. You'll end up with a signifcant difference in your jetting to optimize your O2's. Finally, we've dyno'd about 15 Different Crossrams...There's no rime or reason to any of them. 1963's - 1964's - doesn't matter. The best one John Shaul ever had was a '63. For what your doing, I'd run a New Mopar Perf. with the removable top. They're cheap, and they work really well. You'll just have to tune to yours. Hope this helps, Jim.
Jim Bailey is offline   Reply With Quote
