Old 06-23-2009, 05:42 PM   #1
Michael Pliska
Default Re: Steel caps for 8.75" Mopars???
Originally Posted by ET6201 View Post
The last time I checked, the only pro gears for the 8-3/4" were for the 1-3/4" 'stepped' pinion gears (4.44 and 4.86:1 ratios). That's the only reason I went away from the tapered pinion.
Who still makes pro gears for the 8-3/4"? Is my recollection correct that the above mentioned 1-3/4" stepped pinion is for 742 case?
Thanks,
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
Old 06-24-2009, 06:54 PM   #2
Dusty Lowell
Dusty Lowell's Avatar
Send a message via AIM to Dusty Lowell
No one makes pro gears anymore for an 8 3/4. Well thats atleast what i ran into.
Dusty Lowell
#1773 STK F/SA
Dusty Lowell is offline   Reply With Quote
Old 06-27-2009, 02:58 AM   #3
ET6201
Thanks,
Yes, the 2070742 case is for the 1¾" stepped pinion. The only current source of pro gears (that I'm aware of) for the 8¾" uses this pinion...
Mfr: Strange
PN: RP03987486E
Ratio: 4.86:1
Alloy: 9310
By-Run
ET6201 is offline   Reply With Quote
Old 06-28-2009, 02:06 PM   #4
bill dedman
Liked 6 Times in 4 Posts
So, it looks like the "smart money": is on the 742 case and a mini-spool???
I hate to break down this 2.73 setup in my 742, because it's dead quiet, but money being what it is these days (scarce!) and 742 cases being what THEY are these days (scarce!), I might as well do just that...but, it's going to be a 3.90...This engine combination doesn't LIKE rpms...
That's okay; it's a street car, basically....
Thanks again for all the good information, guys...
Bill
Bill
bill dedman is offline   Reply With Quote
Old 06-28-2009, 02:47 PM   #5
bill dedman
Gettin' too OLD for this *****...
Those third members are getting heavier every year; I ain't gettin' any younger, so I built a "labor-saving device" to aid me in my time of need (old age!!!)
Here are some pictures of my creation; built from a Harbor Freight tranny jack and some 3/16" steel plate, it will roll right up to the rear axle housing and adjust to the proper height and angle so you can just shove the third member right into place without having to lift the %#@*&$%#@!!! thing!!!
I also built a "cradle" to pick it up off the floor and hold it elevated so it's easily attached to the "labor saving device."
Now, I can change a third member without lifting anything heavier than a half-inch ratchet (used to elevate the jack.) Guess I could use an impact tool for that...
Anyway, here are the pictures, direct for my Photobucket account.
I THINK if you click on the "thumbnails" they will enlarge, somewwhat, for better viewing...
Bill
Bill
Old 06-28-2009, 03:22 PM   #6
bill dedman
Maybe I'kll finally get some pictures posted this time...
We'll see...
Sorry for the delay!
Bill
ID:	989   Click image for larger version
ID:	990   Click image for larger version
ID:	992   Click image for larger version
Bill
Old 06-28-2009, 06:16 PM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
i like the cheapo tranny jack thing and i've got one, too.
btw, i bought a 742 empty case off ebay for 51 bucks + shipping....
Old 06-28-2009, 07:31 PM   #8
bill dedman
That's a really good price ($51.00) I think!!!
I'll keep my eyes open.... thanks.
Bill
Bill
