Old 06-07-2009, 10:10 PM   #1
bill dedman
Liked 6 Times in 4 Posts
Default Steel caps for 8.75" Mopars???
I have a bracket car that has a Vortech-blown 360 Magnum, and I am wanting to build a third member for its 8.75" rear end that will have a reasonable life-span.
I have no transbrake, nor high stall converter (it stalls about 2,500 rpm) and the ring and pinon are 4.10:1 ratio.
The tires will be 9"-wide M-T bias-ply slicks (no d.o.t. tires or drag radials) and will be 28"-tall.
I plan on leaving at about 2,000 rpm, if the brakes will hold it still. (Less, if they won't/can't.)
The engine was tested on a chassis dyno @ 477 ft. pounds of rear wheel torque (445 rear wheel hp) at 10 pounds of boost. Abundant low-end torque....
It will hopefully, be capable of some low 1.70 60-foot times, maybe better, but not counting on it.
I have a NEWLY BUILT 489-case center-section (with a crush sleeve eliminator kit installed) that has a cone-type limited-slip unit (this is a street/strip car), with the larger, (7290) u-joint yoke.
I am wondering if I might need to install a steel carrier-bearing back support (CAP) in place of the cast iron one that it comes with (OEM.)
I don't want to have to do this if it's overkill. The car weighs 3,600 pounds and should run mid-11's if it hooks (118 mph.)
I'd appreciate some advice on this from people who have experience with the 8.75" in a moderately powerful 3,600-pound car like mine. {That's 3,600 pounds with me in it, ready-to-race weight.)
Like I said, this is not something I want to do unless it's actually necessary. Do these 8.75" units break that bearing cap in the kind of useage I described? I will only race it occasionally.
Thanks for any information... it will be much appreciated.
Bill
Bill
bill dedman is offline   Reply With Quote
