Liked 132 Times in 30 Posts
I'm curious if super stockers using large tire-ladder bar/4 link suspensions still have advantages over stock/Cal-Trac suspensions with low horspower lightweight (under 3k lbs.) combos?
Gary Smith "another broke racer spectating" |
John Calvert doesn't appear to need big tires and a 4 link. Last I heard he was still running SS with 9" tires and Caltracs.
Ed Wright 4156 SS/JA |
Liked 242 Times in 81 Posts
Steve Wann doesn't have a problem either.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
Some racers (like myself) may go "plenty fast" with a 9" slick w/ Cal-Tracks in SS racing but the problem can be on crappy tracks were that guy is most likely going to be the one with the problem.
Ladder bars seem to be the most forgiving suspension (KISS) you can have.I've never had a 4-links but I see it offer's the most adjustments which can make or break you. I was going to a ladder bar and instead of following my own logic of KISS decided last week to 4-link the car and back-half it.
Jeff Lee 7494 D/S '70 AMX |
Liked 70 Times in 29 Posts
If you can launch an A, B, or C stock running low 10's on a 9" tire, you can launch a super stocker with a smaller motor on a 9" tire.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#7 | |
Trans brakes make a difference there. I had fewer problems hooking my nine second foot brake 383" on 9" tires than my ten second 355" SS engine (same car) with a trans brake and 10.5" tires. Good tracks are no problem, crap starting lines like this last one at Topeka are a bit of an isssue.
