Old 05-13-2009, 08:44 PM   #1
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Red face Jetting Adjustment for Sea Level ?
I imagine that this is probably pretty mundane stuff for most of the guys here
My car runs a pair of 1405 Edelbrock AFB's ( 600 CFM )
We tuned on the dyno in Calagary ( 3500 ft... actually measured 4000 on the barometer )
Current jetting is 92's on all 8 corners, using 7552 metering rods.
Need to make appropriate "enrichment" for sea level.
I don' have the equipment or experience to make the fine tuned changes there, so I need to get a safe, but power making mixture.
It will take no leaner here, as it is.
I'm thinking of bumping up to 95's in the secondaries, and dropping to a 7347 metering rod in the primaries.
Not sure if that's enough though ??
hope you guys can help ?
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 05-13-2009, 10:45 PM   #2
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Default Re: Jetting Adjustment for Sea Level ?
Coming to Mission Aubrey?
Dinsdale is offline   Reply With Quote
Old 05-13-2009, 11:08 PM   #3
Aubrey N Bruneau
Sure hope so !
Been trying to for 4 years now ( it IS a 1500 mile round trip for me ! ).
Watching the weather, and saving money.
Old 05-14-2009, 04:27 PM   #4
MBogina
We use the 9636 Federal Mogul 625 cfm carbs, essentially the same components as your Edelbrocks. If the DA changes 3000 feet, rejet one jet size (ie 92's to 95's). If you would rather swap metering rods, a difference of .003-.004 in the metering rod tip is roughly equivalent to a jet change of one size. if you are borderline lead at 4000+ DA, and the air at Mission is in the area of Sea level or better, you would be safer by jetting up 2 sizes in the secondaries, and one size plus a rod change in the primaries.
MBogina is offline   Reply With Quote
Old 05-14-2009, 05:25 PM   #5
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Talking Re: Jetting Adjustment for Sea Level ?
Think that old truck will make it over the mountains? See you in Mission.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 05-14-2009, 11:50 PM   #6
Aubrey N Bruneau
Heck YEAH, Bob... aint no girly-man small block in there ya' know
Thank you, MB.
That is kind of what I was thinking, but my "thinking" on this subject, at this level ( pun intended ! ), has no basis in experience !
Now, I gotta get a jacket
