Liked 361 Times in 104 Posts
I also race a C-5 and it is all in the suspension, converter and launch RPM with my car.
Hughes converter with 6400 stall. Last year I had to carry .040 to .060 to keep from going red. I ran as high as .090 at one race. I was using 5400 to 5600 in the low chip depending on adjusted altitude and bringing the stop on at .007. Rear shocks rebound in the middle and 2 clicks off of full soft on the compression side. Front shocks in the middle on adjustments. 4 link holes set as Davis set them. I did have to adjust the right rear preload to get it to go straight on launch from where Davis set it up. Every car is different as I have friends who use totally different setups. If someone else does your transmissions and it is a Dedenbear case have you checked the release adjustment on the rear of the case? Hope maybe some of this helps. Good Luck with the issue. |
The difference is in the release, typically the regular brake uses a spring behind the valve for the release. The pro tree brake uses a fluid release. It also requires a second hole be drilled into the case, so once you go pro brake you can't go back. Pro tree brake requires pushing button to get reverse also.
Ron 33 S/C
Ron Finney 396V S/C |
