I know this isn't a bracket site but I also know this is where the info is. Question: 70 Pontiac Lemans,350 c.i. built similar to stock rules, is a powerglide or a turbo 350 more consistant ? Also,car came with a b.o.p. 10 bolt. Is this rear worth putting any money in, or should I go with a 12 bolt ? I'm planning on trying stock in the future so I don't want to spend money where it's not needed. Car is not tubbed and is still in the building stage.It's basically a street car now torn down and getting cleaned,painted and ready for the strip.
Steve |
Liked 880 Times in 311 Posts
I would take a long hard look at where you are going with your project & build with parts that will suit your later needs. Some cars never came with a P/G & only a 3 speed is allowed in those classes. No sense spending double.
my .02 for what it's worth Adger Smith
Adger Smith (Former SS) |
Thanks for the response Adger. I thought some of the 350 engine cars came with the powerglide. If I'm wrong let me know. Thanks
Liked 56 Times in 27 Posts
![]() Steve, As Adger said stay as close to stock as possible..I do think they came with T-350, and yes the T-350 is the way to go...I would leave the tubs STOCK, don't touch them..You can still get a 30X9" radial slick in there on a 10 "rim,with the right off-set....They made two 10 bolt rears, 8.2 and 8.5..The 8.2 is not very strong, but the 8.5 is what I use in my firebird and can handle a 455ci motor if set-up with good parts.You do need to decide if this is a race car or a street car ???? Good Luck Dave...1033/stock( 350)
Dave Ribeiro 1033 STK |
Liked 89 Times in 19 Posts
Both Adger and Dave are correct. It does't appear that a Powerglide was available in 1970. The classification guide does not indicate a difference in shipping weights for TH, usually a clue that the PG was available.
c
Chuck Norton |
Dave:
Is the 8.5 rear a direct bolt in for this car? If so,what cars did they originally come in? I'll start looking for one.What should I expect to pay for a stock one? Thanks |
Liked 5 Times in 3 Posts
A 70 is an 8.2 . if you can find a lemans a few years newer it will be a an 8.5. the chevelle should be the same thing too.
novamoation
The easiest way to spot a 8.5 10 bolt is; it has square corners on the bottom middle near the rear cover.
#9 | |
Pontiac did not use a Powerglide transmission, ever. Neither did Buick or Oldsmobile. They did use a planetary two- speed known as the Super Turbine 300 ,or the Jetaway, depending on the brand. The only thing that's the same as a PG, is the gear ratio (1.76 PG) . The BOP trans is a stronger unit than the PG in stock form, but it never had any aftermarket support. Calling one of these 2- speed transmissions a Powerglide would be no more correct than calling it a Fordomatic or a Powerflite. Now , for your question. Put a Turbo 200 3 speed in it and look for a Chevelle , Monte Carlo or 70 GTO 12 bolt in it in case you ever want to use a 4.33 ring and pinion.
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 04-07-2009 at 11:12 PM. |
#10 | |
Liked 8 Times in 7 Posts
68-72 12 bolt chevelle/70-72 monte carlo rears will be a bolt-in (bring checkbook) 64-67 chevelles are an 1.5" narrower(bring 2 checkbooks)... if you are not going class racing,i'd stick a 9" in it. it'll be cheaper in the long run... |
