Old 02-07-2009, 04:42 PM   #1
BOSSMAN
Default Re: Widest Tire for 66 Impala?
Do you think if I went with a 28" tall I could fit wider? Maybe a 28x11? I did measure the wheel well width at 13.5" inches and I run an adjustable panhard bar to center the rear.
BOSSMAN is offline   Reply With Quote
Old 02-08-2009, 01:29 AM   #2
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Scott, I also run a 68 Impala in I/S (stick) What combination engine do you run? Just curious.
I run a 396/325 at 4095 lbs
I also run Hoosier 30.0'' x 9.0'' on 8" rims, same issues though. I am not too sure centering the rear would help much, possibly with the right amount of backspace and completely folding up the wheel opening lip you might be able to fit 11's?
Will Lamprecht
Stk 1427
