#161 |
Liked 1,836 Times in 417 Posts
Welcome to the "dark side" (NHRA). I wouldn't assume you should have waited, were I in your position. NHRA has not even mentioned that they are considering allowing crate motors. At least not that I've seen or heard, anywhere, unofficially, or officially.
Alan Roehrich 212A G/S |
#162 |
Banned
Liked 235 Times in 110 Posts
LOL......That made my day !
#163 |
To all concerned:
I've read this thread from the beginning and it has gotten away from the intended path, but that is good. I understand most of the comments and see validity in most of them. The one thing that I don't agree with is the word SPEC being misused. When your racing organization publishes what pistons can be used, the size of the rings and location of ring lands, what rods can be used, what size your combustion chamber must not excced, how much stroke can be ground into your crank and how much lift your cam can be. Thats not all of it but I think you might get what I am saying. If that is not SPEC then what is? Seems to me the last stocker engine built here had "SPECS' for many things. If it didn't then we would all build engines with unlimited amount of internal modifications for hauling *** to beat the other racer. Sounds like with no "SPECS" that Stock Eliminator could turn into "My wallet is bigger than yours" Eliminator. Just an observation. Respectfully Submitted, Steve Williams |
#164 |
Banned
[QUOTE= NHRA has not even mentioned that they are considering allowing crate motors. At least not that I've seen or heard, anywhere, unofficially, or officially.[/QUOTE]
NHRA did back when IHRA first adopted the crate motor concept but as usual they would have made it more expensive by requirining a NEW current year spec body (rolling chassis) and a spec. "CRATE" engine. IE: 302 in a new T-Bird, etc. I bet you guys are glad that didnt happen. |
#165 |
Banned
#166 |
XTECH,
LMAO! You have a good point! It has been to an extent that way in some classes, I not going to mention them to protect the names of the guilty, but you are correct. Steve |
#167 |
Liked 10,739 Times in 2,234 Posts
Crate MoPar's in NHRA. The Nascar Hemi with the short or long track intake, any carb that will fit under the hood and aluminum heads.
See there is a place for Crate Motor "Bracket Cars" in NHRA Stock Class! |
#168 |
Liked 6 Times in 4 Posts
>>>>>"If that is not SPEC then what is?"
Read the rule book section on cylinder heads used on a Top Fuel motor. NHRA dictates LOTS of specifications that cannot be varied from. There is no Rat Motored car in Top Fuel, no wedge combustion chambers, and no variation on the type and size of superchargers that are allowed in that class. It is a "SPEC class. I. E., the "specififications" that are legal for that entire class of cars are spelled out for you, and if you want to run a car in that class, you build what they dictate. Period. "Ingenuity in Action," which USED to be one of NHRA's favorite mottos, died in its sleep, and was quietly shoved under the carpet many years ago. In Stock, they do dictate some specifications as to what is allowable for YOUR chosen motor, such as what constitutes a "legal" valve job... (along with other across-the board rules that don't, as far as I'm concerned, qualify the cars as "spec" cars because they can be performed on any car you want to run; a Chevy, Mopar, Ford, AMC, etc....) If they said, All Stock Eliminator cars have to run 23-degree heads, " THAT would be a "SPEC CAR" type of ruling I guess the best example I can think of RE: SPEC cars, is the NASCAR "Car of Tomorrow" that has no room for individuality in the engineering left to perform; it has "SPEC" everything, no matter whether it's a Toyota, Chevy, or, whatever. "Cookie Cutter Car" comes to mind.... NHRA Stock Eliminator has always dictated specifications for the individual (Stockers) cars, and those cars have maintained their mechanical autonomy (at least, to a large extent), because the bulk of the "specs" they must adhere to are the specifications that are pertinent only to that very car. Not a whole lot in the rule book that's trying to make a Street Hemi and a Pinto W/SA car into the same vehicle. That is my own, personal conception of the term "SPEC" car.... Your mileage may vary. ![]() Bill
Bill |
#169 |
I agree with Ken's original premise as it is all bogus replacement parts anyway, so what is the difference? Even the legitamate combos have things like 10-30 too many ccs or 50 HP off the ratings....or three different dyno standards done at different times in automotive history.
It is like my favorite philosophical argument when you start replacing boards on a wooden boat. After you have upgraded a board with new and better wood, is it still the same boat? So, eventually you replace all the boards, is that still the same boat? Many always say yes.....then we forgot to tell we saved all the old boards and put it all together just like the original boat was (back to showroom). Slower, less comfortable, not quite as nice as the "replacement boarded boat", but up to 100% of the original specifications. So if the "replacement" boat is still the same boat, then what is this one we brought back? It is this kind of the scenario required to unjustiably two intake runner cc lists...one for S and one for SS, but equally perposterous. I know that if they allow crate motors in, will they allow the original crate motors like SOHC's, Tunnel Ports, angle plugged LT-'s, ZL-1's, 429 Boss-8V? __________________
Lynn A McCarty 3470 SS |
#170 | |
Liked 2 Times in 2 Posts
Tod |
