Old 11-25-2008, 09:20 PM   #1
40Coupe
Default Re: Rebuild 1969 Camaro frontend
You have a PM.
'67 Camaro
1.25
5.77 @ 118
40Coupe is offline   Reply With Quote
Old 11-25-2008, 10:34 PM   #2
J Kuchel
Banned
Talking Re: Rebuild 1969 Camaro frontend
Thanks for the PM. Appreciate the input.
J Kuchel is offline   Reply With Quote
Old 11-25-2008, 11:04 PM   #3
Liked 1,912 Times in 429 Posts
Most of the stuff in the steering linkage is often Moog or TRW. Most of what is seen in A arm bushings is Del-A-Lum or other Delrin stuff, although there are some using bearings. There's a longer upper ball joint that helps geometry a lot, it's commonly found in circle track stuff. Springs depend on the combination.
Old 11-26-2008, 02:09 AM   #4
Sean Kennedy
Sean Kennedy's Avatar
Send a message via AIM to Sean Kennedy
Originally Posted by 40Coupe View Post
You have a PM.
This is happens a lot, and it is very frustrating.
I monitor these tech forums to try and learn.
I don't see why people think information is so secret that they can't post it on the forum for all to read.
Sean Kennedy is offline   Reply With Quote
Old 11-26-2008, 09:56 AM   #5
mannymen
Liked 13 Times in 7 Posts
Sean Kennedy I hear you. I also wonder the same question. If someone is willing to help one person then why not all.
Gary Wisecarver sells the upper/lower control arm bearings and a quality aftermarket tie rod tube will do. I think Hotchkis and Global West sells them. Ball Joints were already mentioned above
Moog will have the rest.
Pitman arm
Idler arm
Centerlink
Inner/Outer Tie Rods
N/A
mannymen is offline   Reply With Quote
Old 11-26-2008, 10:04 AM   #6
mannymen
Smile Re: Rebuild 1969 Camaro frontend
One last comment.
If ANY of you see me at the Div 3 races (NHRA/IHRA) and need help just stop by and ask. I'll help out as much as possible and I hope any info will be worth a damn to you, but no guarantees it will help
69 Camaro (Blue) running SS/BA or CA and setup to BRACKET RACE in Super Stock
N/A
Old 11-26-2008, 10:14 AM   #7
Bobby Zlatkin
Bobby Zlatkin's Avatar
I find it easier to do front end work (springs, control arms) with the motor in.
The extra weight works to your advantage.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
