You can change the front clip, taillights and dash and run the car as an older coupe that is in the classification guides as a turbo 4. Go to NHRA online and brows through the guides and pick a year.
http://www.nhra.com/tech_specs/class...ion/index.html Mustang used the same body from 79 to 94 so changing years is easy, Then go to the engine specs to make sure you have the right part numbers. http://www.nhra.com/tech_specs/engine/index.html#ford GOOD LUCK |
#2 | |
Liked 70 Times in 29 Posts
He can run that engine in SS/DX. It says any engine. He will need a loaded Brinks Truck parked in the driveway to do it though.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
If you take the turbo off (redo the engine). You can run SS/FS with the car.
Art Leong 2095 SS |
Liked 11 Times in 4 Posts
ART how is your new car coming along? your 4 cyl. should be as fast as any off them out there.
isnt the SS/M? record by Mark Walton at Kearney with a SVO mustang? So its either run it in SS/MX or as a comp car?
