Old 08-05-2024, 10:20 AM   #26
Signman
Liked 269 Times in 99 Posts
Default Re: Header building
Originally Posted by 1320racer View Post
equal length in our cars, cars with the firewall in the stock location, stock frame rails, etc. means sacrificing fit, ease of installation, spark plug access, ground clearance and in some cars, having to remove and or cutting the inner fender wells all for nothing on the time slip.
There are many who will repeat this concept that headers don't mean anything on the time slip. It depends as always.
Had a decent set of headers we made then had a custom set made for the engine combo picked up several MPH and decent amount of ET back to back.
Friend of mine went from a set of box headers to burns stainless design and set of their collectors picked up good amount of ET and a few MPH.
They were told clocking the primary tubes was more important than equal length plus avoiding sharp/tight turns was also.
Depending on how far out to lunch your present set is you could pick up a lot!
