03-26-2024, 02:59 PM | #21 | |
Liked 344 Times in 107 Posts
Re: water pump drive vs electric pump
#2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
03-26-2024, 08:34 PM | #22 |
Liked 179 Times in 64 Posts
Double post
03-26-2024, 08:48 PM | #23 |
I got the pump drive all installed and then to wire it, decided to run a 30A in line fuse and a relay to power the pump and the electric fan. Both on or both off, not sure if I'll like that but there it is.
Relay on right shock tower, |
03-26-2024, 10:10 PM | #24 |
Liked 945 Times in 261 Posts
Personally, I always run the water pump separately from the fan. When you are warming up a cold engine, no need to have the high draw of the fan going, slowing down the warm up. Plus I don`t run the fan going downtrack, blowing hot air back towards the carb.
03-26-2024, 10:27 PM | #25 |
Liked 1,887 Times in 580 Posts
We use the blower motor belt pump on my boy's Stocker and it
cools as well as my aftermarket pump and electric fan. Plus it draws less than 1/2 the amps even running the fiberglass fan than my Pump/Fan setup. We have aluminum Radiators on both cars. Perhaps the aftermarket pumps circulate to fast?
04-09-2024, 04:17 PM | #26 |
I'm thinking I'll change it, not sure when. It's operating now, fine tune later.....does that sound like I'm rushing?? lol.
Jim Miller U/SA "wannabe" |
04-09-2024, 08:26 PM | #27 |
Liked 49 Times in 34 Posts
I had a 2 speed motor from the junk yard but dang I can’t remember what it was off of. Just make sure it has a 1/4” shaft, I even sourced the cog and belt from ‘Mr Gasket’ then made a simple aluminum bracket. Never bought one new in over 50 years. Go to swap meets there’s usually 2 or 3 on a table for 10 bucks.
04-10-2024, 10:17 AM | #28 | |
Liked 90 Times in 51 Posts
5/16" shaft is what's needed. |
04-12-2024, 04:46 PM | #29 | |
(Thanks again Rory)
