Old 04-11-2024, 12:43 AM   #1
David Lee
Liked 346 Times in 126 Posts
Default On a low HP engine
should you have the block align honed?
Old 04-11-2024, 06:36 AM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 985 Times in 314 Posts
Default Re: On a low HP engine
Is the block housing bores straight and the correct size ?
Old 04-11-2024, 07:30 AM   #3
David Lee
not yet, just wanted to know what to tell the machine shop to do
Old 04-11-2024, 08:53 AM   #4
Billy Nees
Liked 7,925 Times in 1,760 Posts
Did you take the block apart? How did the bearings look? The crank? Did the crank spin free in the block?
Billy Nees 1188 STK, SS
Old 04-11-2024, 09:26 AM   #5
richie 2
Liked 205 Times in 93 Posts
aline hone straightens up the thrust bearing area...always a bummer if you find out theres an issue during assembly.
Old 04-11-2024, 11:44 AM   #6
David Lee
i have a bare block and a crank that is in fantastic shape from that came from another engine
Old 04-11-2024, 03:00 PM   #7
Adger Smith
Liked 880 Times in 311 Posts
I've seen too many variabes in factory mass production machining to say No.
I got to where I just lightly trimmed (.001-.002) the caps and dusted the main bores with the align hone on ever engine I built. It was amazing what I ran into.
If it is a SBS or BBC be sure to install the oil pump. When it is torqued it affects the rear main bore.
Adger Smith (Former SS)
Old 04-11-2024, 04:07 PM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 2,007 Times in 602 Posts
I would have the machine shop check the main bore sizes with a dial bore gauge and straight edge to see if the block is straight and true. Somehow hen the block is line honed it causes timing chain fitment issues. You can get undersized sets to compensate for that but can be a pain. In all my years of racing I have only had one block line honed. That was after I broke a crankshaft. That block was never right after that. Ended up scrapping it.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 04-11-2024, 05:28 PM   #9
David Lee
would that be true for a small block mopar?
Old 04-12-2024, 07:49 AM   #10
Liked 11,032 Times in 2,267 Posts
How does the aline hone straighten the thrust area?
Thanks.
