Old 03-11-2024, 02:37 PM   #1
goinbroke2
Liked 405 Times in 158 Posts
Default Re: water pump drive vs electric pump
Thanks for all the replies guys, I'm getting a pump drive from a local S/SS racer. Maybe down the road I'll try an electric pump but I still think it would look silly having a "race" electric pump on a 302 2bbl, LOL!!!!
Old 03-15-2024, 07:58 PM   #2
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Following up Curtis's post above regarding those good quality 4 post drive motors. Installed one, and it works great. It's about 6 oz. heavier than the current replacement Moroso motor. In my application with a well used water pump, overdrive pulley, and "dry", the 4 post unit draws about 3 Amps vs. the Moroso's 3.5 Amps (roughly 3 yrs. of use).
T Ames is offline   Reply With Quote
Old 03-26-2024, 10:34 AM   #3
novassdude
Liked 136 Times in 49 Posts
I don't know if any one is using them on class cars but I am switching to a Davies Craig remote mount water pump. A huge weight savings and they cool some very high HP drag and drive cars.
novassdude is offline   Reply With Quote
Old 03-26-2024, 02:59 PM   #4
JP1738
JP1738's Avatar
Liked 1,365 Times in 368 Posts
I'm with you, but I already had one as a spare for my super gas car so I used it on my 305 station wagon. Busted off a smooth -.19 12.80 with a race water pump lol. And the one I have is a CSR I bought new for like $130.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 03-26-2024, 08:34 PM   #5
goinbroke2
Double post
Old 03-26-2024, 08:48 PM   #6
goinbroke2
I got the pump drive all installed and then to wire it, decided to run a 30A in line fuse and a relay to power the pump and the electric fan. Both on or both off, not sure if I'll like that but there it is.
Relay on right shock tower,
Old 03-26-2024, 10:10 PM   #7
Rory McNeil
Personally, I always run the water pump separately from the fan. When you are warming up a cold engine, no need to have the high draw of the fan going, slowing down the warm up. Plus I don`t run the fan going downtrack, blowing hot air back towards the carb.
NHRA 6390 STK
M/S 85 Mustang
Old 04-09-2024, 04:17 PM   #8
goinbroke2
I'm thinking I'll change it, not sure when. It's operating now, fine tune later.....does that sound like I'm rushing?? lol.
Jim Miller
103 U/SA
