Old 02-21-2024, 07:23 AM   #1
Wrenchead
Default Car on lift
I found a first gen Mustang that has been resting on a two post lift (8ft. In the air) for at least ten years. The car was solid before being raised. It is also in a dry garage.
Will being on a lift for at least ten years negatively impact the structure of the car?
Wrenchead is offline   Reply With Quote
Old 02-21-2024, 08:46 AM   #2
Liked 10,747 Times in 2,235 Posts
Default Re: Car on lift
I would not think so. If it’s suspect take it to a frame shop and have them put it on the numbers. That way you have a good starting point.
Old 02-21-2024, 09:05 AM   #3
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
On those cars if the doors open and close nice all is well.
Old 02-21-2024, 09:14 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
8 feet or 1 foot, no difference, suspended by 4 contact points on the frame. Should be no issue though after 10 years, I’d swap out the shocks, bushings and springs
Old 02-21-2024, 09:28 AM   #5
Woodfin
Liked 286 Times in 108 Posts
I think it will be fine. If it is a complete, uncut car, it has plenty of structure to hold it stable. Also, look over all the sheet metal including the roof. Any buckling would be obvious.
Woodfin is online now   Reply With Quote
Old 02-21-2024, 10:37 AM   #6
Wrenchead
Thank you for the suggestions.
