Liked 586 Times in 162 Posts
I had as much as 6 tenths difference between my good carb and another name carb that seemed fine but ran slow and after much trial and error found 3 qjets that were from .05 slower to .10 slower even though they made more HP on the dyno. All were set up the same metering rods and hangers. All were known builders.
#2 | |
Liked 1,184 Times in 337 Posts
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide Last edited by JP1738; 02-05-2024 at 11:18 AM. Reason: typo |
Liked 1,926 Times in 579 Posts
With a 65 jet in the front it must not have primary metering rods. What rod and hanger are in the secondary’s? does it have a fast throttle plate? Have you worked with the speed of the air flap on the secondary?
Mike Pearson 2485 SS |
#4 | |
What is a "fast" throttle plate? Also have not messed with the air flap but I know that it does open at WOT, just not sure how much or how fast.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
Liked 5,121 Times in 1,952 Posts
Where are you? Division 1 ?
Mexico? If we knew then maybe we could recommend someone that could to help you at the (1/4 mile) track. Who was the previous owner of your car? Who built your 350 trans? Does it have a 2.74 low gear? What rear gear? What rear tire? Where's the other tire and brake?
#6 | |
The car has changed hands multiple times since it last ran, best I can tell it last went down the drag strip in 2015 or so. I do not know who last ran it. No idea on TH350 builder or first gear, but I know it and the converter came out from behind another 305 of similar combo so I'm 90% sure its 2.74 first gear. 5.38 rear gear on a Hoosier 30x9 C06 radial. If you need any more info please send me a PM, I don't want to hash every minute detail of the car out and make the entire forum listen, but I do genuinely appreciate all the people who have reached out or chimed in!
#7 | |
There are many other ways to pick up some ET besides in the Q Jet. Of course Mark Lewis can help with that ,as can Mike McDonald
#8 | |
#9 | |
Don't really need to speed up secondary opening if you are two stepping it off the line.
I don't think we know that yet, either.
