Old 12-08-2023, 07:43 PM   #41
BRETV
Liked 776 Times in 199 Posts
Default Re: Ford 302 SS build
Originally Posted by goinbroke2 View Post
So that's 490-500hp....that's impressive for a non roller gt40 headed 351! (also the first 351w that I've seen make any power with "stock" heads, lol)
Actually made in the 420's on the dyno.
Bret Velde
2003 I/SA
BRETV is online now   Reply With Quote
Old 12-08-2023, 07:48 PM   #42
BRETV
Originally Posted by Chris1529 View Post
I had a 95 F150 with the 351W that I used to tow with. I think it was only rated at 210 HP then with EFI and was a non roller cam as well. It had 325# torque, but at 2800 rpm. It was a really good engine in that truck as far as pulling with a 1/2 ton 4x4. The Lightning trucks of the day had the GT40 heads I think, but I never drove one for comparison.
I also have the parts for a 69 290HP 351W, but feel its too high a factor to start out with in S/SS unless you really want to do it.
The Lightnings those years had the same motor as the Cobra R except the trucks had the tublar GT40 intake and the Cobra had the cast intake. Yes same F3 GT40 heads.
Bret Velde
2003 I/SA
Old 12-08-2023, 10:33 PM   #43
goinbroke2
Liked 385 Times in 150 Posts
Bret Velde
2003 I/SA
So you’re saying internet hp calculators are wrong?😂😂😂
Still impressive!👍🏻👍🏻
Old 12-08-2023, 10:55 PM   #44
James Hill
Liked 10 Times in 4 Posts
Originally Posted by ShipC1970 View Post
I confirmed it’s a 1972 248hp combo and it’s a core. The block casting is D0AE-L. Since that is the same casting number for the 70 and 71 blocks if I somehow found a set of 71 351c heads could I run it as a 71 since the block numbers are the same and do everything else to 71 spec? I’d run it in GT class.
Call Jeff Lawrence at Lawrence Racing Engines before you go down the Cleveland route. There was an aluminum head approved for them at one time I believe, that's probably the way to go (at least you can weld in those).
James Hill is offline   Reply With Quote
Old 12-09-2023, 12:30 AM   #45
Rory McNeil
Liked 1,103 Times in 301 Posts
The casting numbers on the block are not a consideration , the heads (and intake manifold on a Stocker) are. Many engine combinations are allowed to run approved aftermarket blocks.
NHRA 6390 STK
M/S 85 Mustang
Old 12-09-2023, 01:22 AM   #46
Paul Precht
Paul Precht's Avatar
Liked 314 Times in 119 Posts
Jeff should be the first guy to call for sure.
Old 12-09-2023, 02:11 AM   #47
dwydendorf
dwydendorf's Avatar
Liked 19 Times in 7 Posts
I know a little about the 70 351c combination in Super stock since I ran it for a few years. I went a best of 10.53 in ss/j on a 11.05 index in 1993. I went through teardown at the u.s. nationals 3 times with that combination.The Autolite carb is very problematic and can be a real pain. Verne Buchanan is the one to talk to about a carb. Toss the doae-l block aside and get a ford performance boss 351 block windsor based block which is legal. It would be better to run the open chamber 280 hp 71 or 72 266hp in ss-gt. The 220 hp 302 is one of the last things I would consider for that body in super stock, the horsepower rating is too high, you would be lucky to run the index with every trick in the book.
ss/gt 93 t-bird
dwydendorf is offline   Reply With Quote
Old 12-09-2023, 12:50 PM   #48
Liked 5,118 Times in 1,950 Posts
Question for the o/p..
Have you looked into the cost of a competitive S/S Ford engine yet?
Old 12-09-2023, 01:47 PM   #49
ShipC1970
Liked 28 Times in 11 Posts
I have and I know it’s not cheap.
ShipC1970 is offline   Reply With Quote
Old 12-09-2023, 02:39 PM   #50
Not even in the same ballpark as cheap, but good luck ;-)
