Old 12-05-2023, 03:18 PM   #13
ShipC1970
Liked 30 Times in 11 Posts
Default Re: Ford 302 SS build
Originally Posted by Jim Caughlin View Post
You can run GT only if the comb is a hybrid. If the combo can legally be run in SS, you can't run GT. In my case, I am building a '64 Comet with the 289/210 combo. If I run the large Autolite Merc combo, it is a SS/MA. If I run the small Autolite Ford combo, it is a GT/QA. You can't swap between classes, the argument for this rule was that people were running GT with legal SS combos to avoid a potentially losing heads up runs.
So I have a 89 roller 302 in the garage. If I run that block with a set of 68 302 heads I could run it in GT because it would be a hybrid? And I could claim it as the merc 68 302/220 combo with the 4150?
ShipC1970 is offline   Reply With Quote
